Enhanced Object Tracking for Catalyst 3550/3750 series?
Mar 3rd, 2004
  • Bronze, 100 points or more
I was wondering if the Enhanced Object Tracking feature (or a similar feature)
for routers is available for the Catalyst 3550/3750 series. If it's not,
what could be the solution, if there is, for this setup:
WAN <---> L3_switch_1 <---> L2_switch_1 <---> L3_switch_A <---> LAN
WAN <---> L3_switch_2 <---> L2_switch_2 <---> L3_switch_B <---> LAN
- L3_switch_1 and L3_switch_2 are running HSRP.
- L3_switch_A and L3_switch_B are running HSRP.
* Assumption:
L3_switch_1 and L3_switch_A are the Active routers on their respective HSRP groups.
* If the link between L3_switch_1 and L2_switch_1 goes down, we would like L3_switch_A
and L3_switch_B to change HSRP states.
Thanks in advance for any input.
Ariel
carenas123 Tue, 03/09/2004 - 12:09
  • Silver, 250 points or more
Enhanced object tracking feature commands supported from Cisco IOS 12.2(15)T onwards. I didn't find any IOS in 12.2 release for 3550, and but found 12.2(18)SE ED for 3750 switch. Unfortunately, from command reference, I could not find any "track *" commands. So, both Catalyst 3550/3750 switches at present don't support Enhanced object tracking feature.
See the following link for more information...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541be.html
