Cisco 3750 Switch Configuration
Mar 4th, 2004
I am new to switch and i was going through the article about the switches and in the article it says to allow traffic to pass through a particular port, then that port needs to be in the trunk mode. We bought a new 3750 Cisco Switch and the Switch is directly connected to 5 2950 switches and one Cisco Pix firewall and One internal router. An Engineer came and confiugred the same. All internet related traffic hits the switch and gets forwarded to the pix firewall which is working fine. The Enginner had made the ports that are connecting to 2950 switches as trunk port(vlan 10) and access-port for the port that is connecting to cisco pix and internal router with vlan as 30 and 60 respectively. How all vlan traffic can pass through to the Cisco Pix firewall which is connected to a port in the switch which is in access mode and vlan 30? Is there any link that points to some Lab Configuration of switches so that i could get a better understanding of the switch configuration.
Thanks in Advance
Georg Pauwen Thu, 03/04/2004 - 02:15
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
you do not need a trunk port to go to the firewall, as long as the routing on the switch says that all traffic has to be forwarded there. So all that is needed is for all VLAN traffic to be able to reach the IP address of the firewall (through VLAN 30 in that case).
This link might be useful:
Configuring Inter-VLAN Routing with Catalyst 3750 Series Switches
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00801cc828.shtml
GP
kjanakiraman Thu, 03/04/2004 - 19:59
Thanks a lot for your reply. I do not need to make any port trunk if i have a routing statement? I am i correct? I can connect from the switch to a firewall in a vlan and connect from the switch to another router in a differnt vlan and make it as access port as long as there is routing statement? If i am connecting to multiple switches from the core switch then i have to make those ports trunk port from different vlan communication? Is this correct?
Thanks in Advance
