802.1q trunking 2611 to 3524
joe.pollere
I'm trying to set up an 802.1q trunk between the buit-in 10meg ehternet port on a 2611 router and a cat 3524 switch. I am running release 12.2(11)T10 on the router. The subinterfaces will come up but I can not ping any devices on the vlans on the switches.
I know that 802.1q was not supported on the built-in interface till 12.2(2)T but should be with my version.
Are there any special caveats for configuring 802.1q trunking on these interfaces?
Joe
7 Replies 7
msdonahue
Which feature set are you running? The are 14 feature sets available for 12.2(11)T10 but only 8 support 802.1q trunking.
I am running IP Plus.
c2600-is-mz.122-11.T10.bin
Not applicable
What does your subinterface config look like? Do you mind posting it?
Here it is:
*********2600******************
interface Ethernet0/0
no ip address
no ip unreachables
no ip proxy-arp
duplex full
interface Ethernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.8.1 255.255.255.0
ip helper-address 10.10.10.56
no ip unreachables
interface Ethernet0/0.2
encapsulation dot1Q 2
ip address 192.168.8.1 255.255.255.0
ip helper-address 10.1.8.30
no ip unreachables
*****3524***************************
interface FastEthernet0/24
description 2611 router E0/0
duplex full
speed 10
switchport mode trunk
switchport voice vlan 2
Your config looks good. That's exactly how I have mine configured and it works. I'm stumped. Sorry!
ok thanks...at least we know that the config is correct.
Appreciate your help.
I think this is the right moment to use a protocol analyzer.
Configure a SPAN (mirror) port on the switch mirroring the trunk traffic.
Connect a data analyzer (a PC running Ethereal freeware, e.g.) to it.
Try to Ping to/from the router and capture the ICMP frames.
You should see if your router sends/replies the correct frames.
Milan
