Warning message
IP Forwarding Agent / DHCP Client, Virtual IP Router
lisa.hall Wed, 03/24/2004 - 07:00
Can you check if you have enabled Broadcast key rotation. When you enable broadcast key rotation, only wireless client devices using LEAP or EAP-TLS authentication can use the access point. Client devices using static WEP (with open, shared key, or EAP-MD5 authentication) cannot use the access point when you enable broadcast key rotation. This may be the reason for your problem.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
