VPN Client Login Prompt Timeout too short?
Answered Question
VPN Client 4.0.3 / IOS 12.3(2)T4
Is it possible to change the default timeout value for the Username/Password prompt? By default, the users has only 30 seconds to enter their credentials.
I found the IOS command "timeout login respond" wich do exactly what I want but it seems that this command can only be applied under Lines.
Thanks for your help
Correct Answer by gfullage about 13 years 5 months ago
> crypto isakmp xauth timeout
will do the trick for you.
Overall Rating: 5 (1 ratings)
Correct Answer
gfullage Thu, 03/04/2004 - 19:52
  • Cisco Employee,
