PIX 501 FTP config HELP
Mar 5th, 2004
  • Bronze, 100 points or more
Please excuse my noobness, but I need some help with FTP traffic to an internal server on my network. My configuration is pretty simple, i think.
Interfaces:
inside- 192.168.100.254 255.255.255.0
outside- 10.1.10.2 255.0.0.0
The outside IP comes from a Cisco broadband router that I don't have access to. All traffic is directed from our real external IP to the PIX through the router.
I have a FTP server with an internal IP of 192.168.100.13 and all I want to do is direct incoming FTP requests to my FTP server.
I have been using PDM, but also have a console connection.
Please help.....thank you
Dave
mpalardy Fri, 03/05/2004 - 11:45
Hi Dave,
You'll have to do 3 statements to make this working
1)Map the IP address of your inside ftp-server to the outside interface:
static (inside, outside) 192.168.100.13 192.168.100.13 netmask 255.255.255.255 0 0
2)Add an access-list on your outside interface to permit ftp traffic:
access-list outside_access_in permit tcp 10.0.0.0 255.0.0.0 host 192.168.100.13 eq 21
3)Bind the access-list to the outside interface:
access-group outside_access_in in interface outside
You may refer to theses links:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/s.htm#wp1026694
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/ab.htm#wp1067755
Also check for fixup protocol to permit pasv ftp.
Be sure to have this statement on the pix:
fixup protocol ftp 21
Connection will establish on port 21, and subsequent ftp commands on port 20. With this you wont need to manage port 20. PIX will open port 20 between hosts after port 21 was opened.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/df.htm#wp1067379
Hope this help,
Mike
Anonymous (not verified) Fri, 03/05/2004 - 12:28
Mike-
Wow....thanks for the quick response and great info. I just have one question.....
#1 you say to map the IP address of my ftp server to the outside interface:
My outside interface IP is: 10.1.10.2 with netmask 255.0.0.0
Should the statement be:
static (inside, outside) 192.168.100.13 10.1.10.2 netmask 255.255.255.255 0 0 ???
I have fixup protocol ftp 21 entry already.
Thanks so much for your help.
Dave
mpalardy Fri, 03/05/2004 - 13:18
Dave,
Sorry, I should have wrote: "advertise the IP address of your ftp-server to the outside world".
When traffic is needed from lower to higher (eg outside to inside) security level interface, advertising the IP address of the inside ftp-server is required.
If you wish to use the real ip address of your server use the static command I've included in previous mailing.
Or you may advertise the server on a routable IP address on the outside network. eg
static (inside, outside) 172.16.32.64 192.168.100.13 netmask 255.255.255.255 0 0
In this case, users on the outside network will have to do this to access the inside ftp server
C:\>ftp 172.16.32.64
Do a "show xlate" and "show conn" commands on pix will help you to debug.
Mike
Anonymous (not verified) Mon, 03/08/2004 - 11:54
somebody please help!!
I just can't get this server going. Below is my current config. Whenever I set my FTP server's IP address to 192.168.100.13 I lose all connectivity, no internet connection or anything. If I change it to 192.168.100.14 I have access out, but of course the PIX will not let any FTP traffic in. Is the problem my router? My ISP has it configured to have an inside IP address of 10.1.10.2 and has assured me it will pass all data to the PIX.
Hmmm....I don't get it:(
Thanks for the help
Dave
: Saved
: Written by enable_15 at 06:20:15.110 UTC Mon Mar 8 2004
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list ed_splitTunnelAcl permit ip any any
access-list inside_outbound_nat0_acl permit ip any 192.168.10.0 255.255.255.240
access-list outside_cryptomap_dyn_20 permit ip any 192.168.10.0 255.255.255.240
access-list outside_access_in permit tcp 10.0.0.0 255.0.0.0 host 192.168.100.13 eq ftp
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 10.1.10.2 255.0.0.0
ip address inside 192.168.100.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 192.168.10.1-192.168.10.10
pdm location 192.168.1.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.100.13 192.168.100.13 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 10.1.10.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 0.0.0.0 0.0.0.0 outside
http 192.168.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set XXX
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set XX
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup XXXX address-pool ippool
vpngroup XXXX dns-server 192.168.100.1
vpngroup XXXX split-tunnel XXXX_splitTunnelAcl
vpngroup XXXX idle-time 1800
vpngroup XXXX password x
telnet 0.0.0.0 0.0.0.0 inside
telnet 192.168.100.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:XXX
Anonymous (not verified) Mon, 03/08/2004 - 13:07
This server will only be used for FTP, and I would like to be able to have MX records point the domain name to the server if possible.
thx again
mpalardy Mon, 03/08/2004 - 13:11
Dave,
Can you setup a syslog server with debug information and post the result here.
Mike
Anonymous (not verified) Mon, 03/08/2004 - 13:32
I have not done that before. Can I just send the log to the console?
Anonymous (not verified) Mon, 03/08/2004 - 13:52
OK- I found the documentation for the syslog, but I will have to wait until tomorrow morning so I can test while there is no traffic on the network. It's almost 5pm here now, and I will run the syslog and capture output and post here around 8am tomorrow.
My email address is my name if you want to contact me off forum.
Thank you for your help.
Dave
sateeshk Mon, 03/08/2004 - 19:37
hi
try this
static(Inside,outside) 10.1.10.3 192.168.1.13 dont give mask...
Give the required access-list..
Sat
Anonymous (not verified) Wed, 03/10/2004 - 08:40
sorry for the delay in responding. work is pretty busy here, and I do much more than systems admin. anyway, thanks SO MUCH for the input. i may have another issue with the NIC in my linux box. i'm looking into it now, and will post the results here soon.
Dave
