NM-HDV versus 6608-T1 Question
Mar 6th, 2004
We are in the process of replacing two different
gateways using NM-HDVs and VWIC-MFTs with a
single 6608 module.
One of these NM-HDV's has a VWIC-MFT with a T1 with
only ten of the channels active from the telco for
us being 1-10. The telco has "reserved" channels
13-24 for some other purpose.
I am having trouble finding where I can restrict or
define the channel range that a 6608 T1 port can use.
The NM-HDV was pretty obvious using the ds0-group
and related commands.
The issue is that the 6608 sometimes seems to try and
send calls out via 13-24 during testing which is not
a desired effect. We want the 6608 to start at 10
and work towards 1 for outcalling; whereas the telco
starts at 1 and works towards 10 for inbound calls.
The setting is probably obvious; but if someone can
point it out; thanks in advance.
Overall Rating: 5 (1 ratings)
pbarman Sat, 03/06/2004 - 19:19
  • Silver, 250 points or more
Yes you can restrict the channels on the 6608 T1 to 1-10. Under CallManager service parameters (advanced), specify this for the "Change B-Channel Maintenance Status 1"
---> [email protected] = 0000 0000 0022 2222 2222 2220
0= InService
1= Take out of service gracefully
2= Forcefully out of service
For outcalling with channels starting from 10 to 1, under the gateway configuration for the 6608 blade, specify "Bottom Up" for channel selection order.
Hope this helps,
Partha
pbarman Sat, 03/06/2004 - 22:23
One more thing is, you need to check the "Enable Status Poll" check box on the 6608 gateway settings.
