Limit CfwAll
Answered Question
Mar 7th, 2004
Can i limit to 4 digit the funtion of CfwAll??
Thanks.
Correct Answer by c-charlebois about 13 years 5 months ago
Here's an example:
3 sites: Site A, Site B, and Site C. Each site has local gateways and belong to one cluster.
Each site has one partition for the local phones and another partition for the local PSTN gateways.
Create a Internal_CSS calling search space that only includes the local phone partition for all three sites. Assign this CSS to the call forward all. So long you make sure all route patterns that specify a PSTN gateway are in the gateway partitions and the Internal_CSS does not specify a gateway partition, then no one will be able to cfAll to a PSTN number.
Overall Rating: 5 (1 ratings)
Erick Bergquist Sun, 03/07/2004 - 15:11
  • Silver, 250 points or more
You can put CfwdAll in it's own CSS so it can only call partitions listed in that CSS and the none partition.
You can also remove the Cfwdall from the softkey template.
josegre Mon, 03/08/2004 - 06:37
I dont think that it resolve my problem, because thata i want to do is limit call to 4 digits so that the users cant make forward out of the building.
Erick Bergquist Mon, 03/08/2004 - 08:01
If you put a CSS on CfwdAll that can't get to route patterns, etc that call outbound then when someome CfwdAll their phone that number can't be dialed because it isn't reachable in the partitions the CfwdAll CSS is set to. You can't limit the number of digits dialed. CSS and partitions limit what can be dialed and not dialed.
If you have Route Patterns, gateways, etc in the default/none partition then they need to be put into their own partition as the none partition is always searched.
josegre Mon, 03/08/2004 - 09:22
Please, Can you be more specific? because i have configured diferents CCS for each branch and i cant understand you.
Correct Answer
c-charlebois Mon, 03/08/2004 - 10:43
Here's an example:
