Warning message
CDP-4-DUPLEX_MISMATCH errors
Mar 8th, 2004
  • Bronze, 100 points or more
Hi All,
I am hoping for some help with a "duplex mismatch" problem I'm having.
I have 2 switches (a Catalyst WS-C2924M-XL with a WS-X2922-XL-V module, & a Catalyst WS-C1924C-EN) connected via fibre. The 2924 port is configured as "100/full" while the 1924 port is configured as "Full duplex-flow control".
I regularly get the folowing message in the 2924's log buffer:
%CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet2/1 (not half duplex), with JNR_LIB_SW A (half duplex).
Now as far as I can see both ends are configured for full duplex. If I configure the 1924's port to be "half duplex" the messages stop. Network performance is poor either way.
Can anyone tell me what's going wrong here, & how to fix it? Many thanks in advance for any help provided.
Cheers,
Dirk
Georg Pauwen Tue, 03/09/2004 - 00:52
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
Hello Dirk,
what happens if you change the settings on the 1924 port to duplex full instead of duplex full-flow-control ?
GP
Anonymous (not verified) Tue, 03/09/2004 - 14:31
Hi GP,
Unfortunately changing the 1924 port to "duplex full" makes no difference. Our 2924 is the main switch on our network, & it has 6 other switches (all Cisco 19xx & 29xx) linked via fibre to it. I am getting the same message on 2 other switches, both of which are 19xx.
I would love to be able to fix this as our network performance on these links is poor.
Cheers,
Dirk
