Warning message
View Hostname in RME instead of IP
Mar 9th, 2004
I have just sync'd the ANI db with RME and I only see the IP address in RME. I have read a previous conversation stating that you must use DNS. Is it possible to only use a host file instead of DNS?
thanks much!!!
kelly-john Mon, 03/15/2004 - 07:27
Yes, a hosts file on your server will work OK. You need to make sure that Campus Manager has found the hostnames first (you may need to run a discovery again) and then do a bulk import into RME.
