03-11-2004 01:42 PM - edited 03-13-2019 04:14 AM
Hi guys, I can't seem to get extension mobility to work. I got as far as to see the "login" and "logout" service on the IP phone when the services button is pressed, but when selected each show some html/xml code. Any suggestions as to what I am not doing right. Appreciate any assistance given. Thanks in advance
03-11-2004 08:01 PM
What is the URL of the login service in Callmanager, is it something like :
http://
In CRA, did you HTTP trigger name as /login.
This link may help you:
03-13-2004 07:14 PM
You haven't mentioned which CCM version you have, so I assumed it was CM 3.2 because in CM 3.3 you generally have only one service called "Extension Mobility" to serve both login and logout process.
I saw this question in another post of yours in Certification forum, and there you mention that you have CCM version 3.3. So, I assume you have upgraded CM to 3.3. You may check if after the upgrade, you followed the procedure in this link to get Extension Mobility working:
Thanks!!
