Warning message
CLI "Set" Commands
Learning a Cisco 2900XL; IOS Version 12.0(5)WC5.
I've not been able to get any of the "SET" commands to work. Example: set time (for system clock), set system name, etc.
All the documentation I've found shows the Privileged EXEC prompt as Switch#, but the Command Reference and some other docs I've found show the prompt as Switch> (enable).
In either case, I'm not having any luck with the commands. Any suggestions?
Thanx
