Warning message
Ciscoworks: error msg when installing packages
Mar 11th, 2004
When I was try to upgrade the nmidb it always failed, below is the msg. Did I miss out any steps.
Einn
Please wait, installing packages. This could take several minutes....
Pre-installing package nmidb(1.0.082)
Installing package nmidb(1.0.082)
Package installation failed: error in opening zip file
Updating installed repository...
Installation has failed
Martin Ermel Fri, 03/12/2004 - 00:30
  • Blue, 1500 points or more
If you are using the application "package support update" (PSU) for CiscoView do not select the nmidb file for to update. If information from this file is needed, it will be used automatically (e.g if you are using CiscoWorks Windows it is necessary for to update MIBs and traps in WhatsUP Gold)
regards,
Martin
