Warning message
2950 Bad image loaded - fix?
Mar 12th, 2004
I loaded an image through ciscoworks last evening adn the image is bad. But it also wiped the original image (even though I had everything checked to ensure low risk).
Now the switch boots up to this prompt
switch:
with a few things I can do. How do I reload a new image to this thing?
Thanks for all your help!
-Tim
vkapoor5 Thu, 03/18/2004 - 08:29
  • Bronze, 100 points or more
Download the image and put into your system for which switch console connected by hyperterminal.
Follow this procedure from "switch:" prompt...
1. flash_init
2. load_helper
3. copy xmodem: flash:
4. set BOOT flash:
5. boot
Note : After issuing 3rd command, then use Hyperteminal->Transfer-->send file to select the image to be uploaded to switch with PROTOCOL "xmodem". Please refer the following document how to use "xmodem" transfer with Hyperterminal.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Anonymous (not verified) Thu, 03/18/2004 - 10:08
You need to do XMODEM to upload the IOS image
The following are the XMODEM procedures :-
Switch: flash_init (return)
Switch: load_helper (return)
Switch: copy xmodem:filename.bin flash:filename.bin (return)
After pressing the enter button, go to the command line of hyperterminal, select transfer then Send file. Press the browse button and find the IOS image. Change the protocol to xmodem and press send. At this point the switch will start to download the IOS image, it could take up to 45 minutes.
Switch:
Switch: set BOOT flash: filename.bin (return)
Switch:reset
