errdisable on switchport
Mar 14th, 2004
how do we rectify errordisable problem..sometimes i just need to shutdown the port and enable it again..but the worst thing is sometimes doing same thing is not rectifying the problem and requires rebooting the switch.
pls advise.
Craig Norborg Mon, 03/15/2004 - 07:02
  • Bronze, 100 points or more
Almost all switches have some form of errdisable recover, just a matter of what it will recover from. Try here for more info, depending on what switch you have and/or OS level will make a difference in what you can recover from..
http://www.cisco.com/en/US/customer/products/hw/switches/ps628/products_command_reference_chapter09186a00801a6c32.html#2946661
Of course, taking care of whatever problem prompted the errdisable also helps...
To see the reason, try
sh errdisable recovery
it will usually show you the reason for the errdisabled port.
To recover on most ports, simply shut/no shut the interface.
rpalacio Sat, 03/20/2004 - 02:58
as ive told, somtimes disabling and enabling the port will solve the problem but sometimes not.
kodered Sun, 04/11/2004 - 18:44
So, what kinda links are they?? Gig links? You most likely have a faulty GBIC. past that, test your fiber or whatever cabling(i.e. fluke meter)you have. One of these is most likely your culprit.
(0_o)
glen.grant Tue, 03/16/2004 - 13:22
  • Purple, 4500 points or more
Most of the newer switches also have the option to have the switch try and bring it back up automatically after a specified period of time , but this does not find the cause of the problem .
