03-15-2004 05:19 AM - edited 03-02-2019 02:16 PM
which of the cisco pri switch type should be used to connect to a PBX which supports
""- Euro-ISDN E-DSS1and ETSI-compliant""
Many thanks
Larry_s
03-15-2004 02:11 PM
For the E-DSS1 you'd use switch type basic-net3.
Here's a link to the different Cisco supported ISDN switch types.
03-16-2004 05:23 AM
Chuck
Thanks for the reply
Can a PRI interface be configured for Basic-Net3
I know this id normally a BRI switch type.
Larry_s
03-17-2004 07:37 AM
It should be able to be configured. It is not a BRI only switch type. According to Cisco this is what basic-net3 is for. To verify you could call your provider for more info.
basic-net3 NET3 ISDN and Euro-ISDN switches (UK and others), also called E-DSS1 or DSS1
