Warning message
Monitoring CAt 4006
Mar 16th, 2004
  • Bronze, 100 points or more
I have been asked to run a network scanner/sniffer on our switch to see what the traffic is like. I know that spanning needs to be set in order for one port to see all of the traffic of the switch. I have looked and saw how to configure to scan one port. Is there an easy way to monitor all of the ports to see what the traffic is like? What would the commands be? Thanks in advance.
paulo.s Tue, 03/16/2004 - 09:58
Hi, I configured this way, because I use vlans.
set span 65,71-76,82-86 3/11 both inpkts disable learning enable create
For ports you can use :
set span
for example : set span 3/1-30 3/45
bye,
Paulo
milan.kulik Wed, 03/17/2004 - 08:04
  • Red, 2250 points or more
Hi, you can even use
set span
Example set span 1,2,3 3/44
But be carefull, many span sources could overload your Cat4000 CPU and you also would loose frames when the mirrored traffic exceeds the destination port bandwith.
Milan
