Warning message
PIX 515
Mar 16th, 2004
  • Bronze, 100 points or more
Can I replace first firewall and first router (from internet side) with one cisco PIX 515 firewall?
In that case firewall will be connected direct to www, mail, ftp serwer, router for workgroup and server with IPSec for wi-fi
http://www.cisco.com/en/US/products...4094/index.html
It have NAT, DHCPD and can operate on 6 10/100 Fast Ethernet interfaces.
Is this possible/good solution ??
vmiller Wed, 03/17/2004 - 13:23
  • Gold, 750 points or more
you can replace the firewall. Pixes do not route.
IAN WHITMORE Fri, 03/19/2004 - 07:47
  • Silver, 250 points or more
Not possible/ not good (actually I don´t know if it´s possible-depends on your routing). I DO know that PIX´s are not routers and cannot route so it´s not a good idea. I also know that the Cisco recommended solution (SAFE) is to have an external router as your permiter (first-line) security.
Basically, plug router into e0 interface on the PIX and the other end into ISP. PIX default route sends all traffic to router ethernet interface. Much easier this way!
