03-17-2004 05:38 AM - edited 03-02-2019 02:20 PM
Dear All,
i have a problem upgrading the NAM module: check below my status:
root@NAM1.wanna_upgrade# show version
NAM application image version: 2.2(1a)
Maintenance image version: 2.1(1)
NAM Daughter Card Micro code version:1.31.1.27 (NAM)
BIOS Version: 4.0-Rel 6.0.4
I'm patching the NAM with Cat6500 NAM Application Image Release 2.2 Patch 1.0
Whenever i try to upgrade to the Application Image Release 3.1-1a for Catalyst 6500 the following error appears:
Verifying c6svc-nam.3-1-1a.bin.gz. Please wait...
Error: Verification failed.
Error: The patch you are trying to apply is not valid,
or not compatible with this release.
Error: Cannot continue with patch apply. Exiting...
I need to upgrade, need to view the Reporting tab..
Any help..!!
Tamer
Solved! Go to Solution.
03-17-2004 07:20 AM
It seems you are upgrading application image when booting into application partition. Remember that if you want to upgrade application image, you need to boot into maintenance partition and vice versa
03-17-2004 07:20 AM
03-17-2004 07:46 AM
It seems that it works..
Thanks & Regards..
