Warning message
Config for ATM for Disaster Recovery
s-moriarty Mon, 06/21/2004 - 22:41
This is definitely possible. You may want to consult with your carrier. I know that AT&T and SBC both support Disaster Recovery options. It will be up to you to let them know you desire this configuration so that they can set it up on their side too. It is best to contact them directly as they will have more specifics for you than I can provide. Hope this helps...
