DLSw QLLC support for SVC's
Mar 17th, 2004
i try to replace my IBM3745 X.25 Multichannel by Serial Port of my Router. Therefore i have to support SVC's. I do not have the X.121 addresses of the SVC clients, so i cannot define "x25 qllc map...".
i can't find a example for definig something like a vmac address pool for incoming SVC's?
regards
Frank
mbinzer Wed, 03/24/2004 - 04:54
  • Cisco Employee,
i am not that much of an expert for qllc but i think you need to look at the following command.
qllc accept-all-calls
that way we learn the caller x25 address. Something like this.
int s0
x25 addr 123456
qllc dlsw vmac 4000.7200.0000 100 partner 4000.7513.0000
When you search for documentation you also need to look for qllc and dlsw.
The above command excepts all incoming calls and uses a vmac pool of 100 addresses starting at 4000.7200.0000 for the incoming x25/qllc calls and is using 4000.7513.0000 as destination mac address for the dlsw circuit to connect to the host.
