Warning message
Handset not active when taken of hook on incoming calls
Mar 18th, 2004
  • Bronze, 100 points or more
I got the problem that sometimes on incoming calls on to an IP Phone (7940/60) when i take the handset
the call is not active on the handset. Via the Softkey "Answer" i could take the phone but only on the speaker.
CCM is 3.3(3)sr 3
Phoneload is P00305000301
Did somebody have some issues like this?
Thanks for any information regarding the problem.
Roger
Overall Rating: 4 (2 ratings)
rwiesmann Thu, 03/18/2004 - 08:10
Thanks for you feedback but i can not get access to
the link you posted.
Domain seams wrong (www-tac.cisco.com).
So maybe you can post it again so i can access it.
Roger
pbarman Thu, 03/18/2004 - 08:17
  • Silver, 250 points or more
You cannot access that link, neither can I because it belongs to Cisco's intranet. The reason I gave the link is for the Cisco engineer to reference it if you open a Cisco TAC case.
rwiesmann Thu, 03/18/2004 - 08:41
o.k. but do you have more information to what
is wrong whith the hookswitch?
Roger
pbarman Thu, 03/18/2004 - 09:15
Since the field notice is internal, I cannot give you more information. This is a manufacturing defect.
Engineering failure analysis has determined that out-of-spec vendor components may have made these early phones susceptible to hookswitch failure.
We have spent several hours troubleshooting this issue, hope you don't have to do that.
