Warning message
Redistribution from EIGRP to OSPF
Answered Question
Mar 19th, 2004
Just looking for some confirmation for my brain on this one.
Let's say you have a network running OSPF on one side, and EIGRP on the other. There are two points of redistribution (for redundancy, lets call them ASBR1 and ASBR2) performing mutual redistribution (EIGRP into OSPF, and OSPF into EIGRP). This is controlled via distribution lists both ways to ensure OSPF sourced routes are not picked up in EIGRP and redistributed back into OSPF, etc, etc...
Let's say we add a static route in EIGRP and redistribute that. It becomes an external EIGRP route with an admin distance of 170 (along with the OSPF derived routes). We pick this up on the ASBR's, and happily redistribute this route into OSPF with it's default admin distance of 110.
Here's where the problem begins (i think)
Now we have an EIGRP static route floating around EIGRP with an admin distance of 170, and the same route floating around OSPF with an admin distance of 110. Due to OSPF's link state database, each point of redistribution MUST know about the other, hence these ASBR's both see the EIGRP sourced route, AND each others redistributed OSPF route for the same network, except now the OSPF route is preferred due to it's lower admin distance.
Does this make sense? Seems to only be a problem redistributing EIGRP external routes into OSPF, however there doesn't seem to be much info on it, and it seems to me this would be a fairly well documented issue. I've checked all the redistribution dox and not one mentions this could be a potential problem.
Solution:
Use the distance command on each ASBR raising the admin distance on those EIGRP static networks to something higher than 170 so they prefer their EIGRP routes.
ie. ASBR1 would have the distance command configured to raise the admin distance on all external routes coming from it's neighbor ASBR2.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/ip_c/ipcprt2/1cdospf.htm#11650
Sound about right?
Correct Answer by Harold Ritter about 13 years 5 months ago
The filter_redist_eigrp needs to look something like this:
route-map filter_redist_eigrp deny 10
match tag 55
route-map filter_redist_eigrp permit 20
The rest looks good.
Hope this helps,
Overall Rating: 4.2 (4 ratings)
Harold Ritter Fri, 03/19/2004 - 18:29
  • Cisco Employee,
This is indeed an issue. The solution is as stated in the documentation you referred to, which is to raised the admin distance of OSPF external routes to something higher than 170. You have to be careful to to experience the same issue in the other direction if you redistribute external routes (coming from other sources than EIGRP) in EIGRP.
Hope this helps,
ruwhite Fri, 03/19/2004 - 18:41
  • Gold, 750 points or more
Another option would be to tag the route coming into OSPF, and then filter the tagged routes from the local routing table on the other ASBR on the OSPF side. You can also tag the routes on the EIGRP side, and deny them on the other EIGRP redistribution router, as well. For the OSPF side, see:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a008012db77.html
For EIGRP, see:
http://www.cisco.com/en/US/tech/tk365/tk207/technologies_tech_note09186a008009487e.shtml#ex3
Hope that helps....
Russ.W
RYAN BARNES Mon, 03/22/2004 - 11:12
We've been looking at tagging for a while, so perhaps this is as good a time as any ;-)
This basically means I'll need both a redistribute route-map to tag/filter both BOTH protocols AND an inbound distribute-list on the OSPF interfaces to filter the redistributed EIGRP routes, right?
router ospf 1
redistribute eigrp 1 route-map eigrp_to_ospf subnets
distribute-list route-map filter_redist_eigrp in FastEthernet 0/0
router eigrp 1
redistribute ospf 1 route-map ospf_to_eigrp metric 1000 100 255 1 1500
route-map eigrp_to_ospf deny
match tag 44
route-map eigrp_to_ospf permit
set tag 55
route-map ospf_to_eigrp deny
match tag 55
route-map ospf_to_eigrp permit
set tag 44
match tag 55
Thanks for the confirmation and the additional info guys.
Correct Answer
Harold Ritter Mon, 03/22/2004 - 11:48
  • Cisco Employee,
match tag 55
Hope this helps,
RYAN BARNES Mon, 03/22/2004 - 11:56
Whoops. You're right. Guess I'd have to allow the rest in wouldn't I.
Thanks again for the great info guys.
Muchos Gracias.
