Warning message
How to measure Jitter
Mar 21st, 2004
I'm running two SAA probes to measure Jitter, whenever polling any jitter oid (SumRTT, etc) I'm getting two instances as seen below (3.346676620&
3.347036620 ) what are these instances.
host# snmpwalk -v2c -c Cisco 1.1.1.1 .iso.3.6.1.4.1.9.9.42.1.3.5.1.12.3
SNMPv2SMI::enterprises.9.9.42.1.3.5.1.12.3.346676620 = Counter32: 4914
SNMPv2SMI::enterprises.9.9.42.1.3.5.1.12.3.347036620 = Counter32: 4048
ksaad Fri, 03/26/2004 - 19:39
Thanks Jsivulka,
The document you mentioned is good but it does not answer my query what are those two values.
I have found out that the first value is the last hour
statistics and the second is the current hour statistics.
Thanks again for your reply.
grayd Fri, 03/26/2004 - 13:18
You have two collections set up so each collection has an instance. You can issue the "sh rtr conf" on the router to determine which collector is which.
minie Sat, 03/27/2004 - 06:12
  • Bronze, 100 points or more
To answer your question, we really need to get into how MIB works.
The object you are talking about belongs to rttMonJitterStatsEntry. This entry is indexed by two objects, rttMonCtrlAdminIndex and rttMonJitterStatsStartTimeIndex, which means every object in this entry will be indexed by above two.
rttMonJitterStatsEntry OBJECT-TYPE
SYNTAX RttMonJitterStatsEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"A list of objects which accumulate the results of a
series of RTT operations over a 60 minute time period.
This entry is created only if the rttMonCtrlAdminRttType
is jitter. The operation of this table is same as that of
rttMonStatsCaptureTable."
INDEX { rttMonCtrlAdminIndex, <--
rttMonJitterStatsStartTimeIndex <--
::= { rttMonJitterStatsTable 1 }
So enterprises.9.9.42.1.3.5.1 is rttMonJitterStatsEntry. enterprises.9.9.42.1.3.5.1.12 is rttMonJitterStatsNumOfPositivesSD. The 3 after 12 is the rttMonCtrlAdminIndex, and that big number at end, needless to say, is rttMonJitterStatsStartTimeIndex.
ftp://ftp.cisco.com/pub/mibs/v2/
