Warning message
PIX525 Gigabit performance
Mar 24th, 2004
To have the PIX525 firewalls support 100Mbit+ speeds, gigabit NIC's will be added to support this. Does anyone have any experience how much traffic a PIX525 can actually support with gigabit NICs? I realize it's based on the amount/intentisty of ACLs, but I'm just curious if there are any obvious threshholds to watch out for.
scoclayton Wed, 03/24/2004 - 13:37
  • Gold, 750 points or more
The interface throughput on a PIX 525 is about 340 mbps and the aggregate throuput on a 525 is about 370 mbps. The reason for this is mainly that the 525 only has a 32 bit 33 mhz PCI bus.
I view the 525 as a PIX that is able to connect to gigabit networks. If you need a true gigabit firewall, you will need to upgrade to the PIX 535.
Hope this helps.
Scott
