Bug with Network show assign users
Mar 25th, 2004
Using RME 3.5 IDU 7 on W2K server
When launching RME -> Admin -> Config Management -> Network Show -> Assign User, i've a red cross on my screen and the following msg in Java Console :
Return Value: maxcommands = 6
Return Value: maxcommandsets = 6
Return Value: maxdevices = 10
Return Value: maxthreads = 10
Return Value: debuglevel = 0
java.lang.NullPointerException
at com.cisco.nm.netshow.NSAssignUsers.<init>(NSAssignUsers.java:78)
at com.cisco.nm.netshow.NSAdmin2.initialize(NSAdmin2.java:79)
at com.cisco.nm.cmf.ui.wizard.CrmApplet.createNewWizard(CrmApplet.java:213)
at com.cisco.nm.cmf.ui.wizard.CrmApplet.addContents(CrmApplet.java:159)
at com.cisco.nm.cmf.ui.wizard.CrmApplet.init(CrmApplet.java:94)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Any idea ?
Martin Ermel Wed, 03/31/2004 - 23:30
  • Blue, 1500 points or more
could it be that you have the wrong java version? a red cross means that the plugin can not be loaded.
with IDU 7 you should have JRE 1.4.1_02.
or try this(if JRE is correct ver):Log out of CW2k, clear your browsers cache, close *all* open browser windows, clear your java cache (control panel-java plugin-cache) reopen your browser and try it again.
