03-26-2004 03:12 AM - edited 03-02-2019 02:34 PM
Since upgrading to Windows XP when I telnet to a Cisco Router/Switch and use the Up arrow key to repeat the last command the command is displayed but a '^@' is put on the end of the line. I think this is linefeed or something so I cannot change the text. Does anyone know how to fix this very annoying prob. Thanks..
03-26-2004 07:01 AM
I suggest using the program putty, it's better than telnet on windows.
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
03-26-2004 07:08 AM
I strongly second that sentiment.
Don't use the built in telnet client or HyperTerminal. Get a proper telnet/ssh client.
= K
03-27-2004 04:26 AM
Thanks guys, great little program.
