Warning message
Newbie PIX-501 config
Mar 26th, 2004
  • Bronze, 100 points or more
I have very little exp with router/firewall. I have the vpn working using the PDM wizard. I want to make my websever avail to the outside. I am not understanding what command combinations allow port 80 traffic through and forward to my internal web server. I am assuming I can do both VPN connections and webserver forwarding with a single public ip address.
Thanks!
Anonymous (not verified) Fri, 03/26/2004 - 14:34
I have 1 public IP addresses assigned to the pix (Does that put me running pat?) It is the address assigned to the Outside interface. I have 2 more avail Public IP's if I need them.
bahoosh Wed, 06/23/2004 - 11:51
All you need is two statemnets ... one static and one access-list
it goes something like this:
static (inside,outside) your_public_ip your_www_ip net 255.255.255.255
access-l outside_in permit tcp any host your_www_ip eq www
