Warning message
How to upgrade Boot Flash
Mar 29th, 2004
Hi..i have a AS5300 with this boot flash
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.2(2)XA3, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
How can upgrade to a higher version or fix it..it keep crashing
Boot flash directory:
File Length Name/status
1 1778104 c5300-boot-mz_122-2_XA3.bin
2 179741 crashinfo_20040329-120348
3 181800 crashinfo_20040329-140359
4 178303 crashinfo_20040329-142934
5 178632 crashinfo_20040329-150123
6 174137 crashinfo_20040329-151250
7 177576 crashinfo_20040329-162135
8 174504 crashinfo_20040329-171247
[3023316 bytes used, 5365292 available, 8388608 total]
8192K bytes of processor board Boot flash (Read/Write)
sarmentrout.bok77 Fri, 04/09/2004 - 19:58
How do you know it is due to your Boot Flash? When your router crashes, it stores all crashinfo files into bootflash (most models). If you haven't already, you need to look at the latest crashinfo file (open in notepad) and see what process is causing the crash (or at least what is going on when it crashed). You also may be able to retrieve this information from a 'show tech' if the router was not reloaded after the crash...
