Warning message
local ip ftp access
Mar 30th, 2004
I want to setup a local client to have the only ip addres with ftp access.
Do I have to create a static ip for the local ip address with a conduit to the foreign host ip?
Does fixup protocol 21 have to be enabled? My goal is to have only one local ip have access to ftp.
Thanks in advance.
Overall Rating: 5 (1 ratings)
gfullage Tue, 03/30/2004 - 15:53
  • Cisco Employee,
Just create an access-list on your inside interface that only allows that one internal PC to FTP outbound. The PIX will use the standard nat/global (or whatever you have) as normal for this host, nothing needs to change there. Leave the fixup enabled also.
Do something like the following:
access-list outbound permit tcp host any eq ftp
access-list outbound permit tcp host any eq ftp-data
access-list outbound deny tcp any any eq ftp
access-list outbound deny tcp any any eq ftp-data
access-list outbound permit ip any any
access-group outbound in interface inside
acira Wed, 03/31/2004 - 08:39
That did the trick.
I just created the outbound deny and then followed up with the outbound permits.
You've been a big help.
Thanks again.
