Warning message
RRAS opens 1645,46 preventing ACS from installing
Mar 30th, 2004
RRAS (not IAS!) on W2K opens ports 1645,46. When I try to install ACS 3.2 it says that radius ports are alredy opened. What should I do if I need RRAS and ACS on the same server?
didyap Mon, 04/05/2004 - 13:23
  • Silver, 250 points or more
It is recommended that you place them on different servers. However, if you keep them on the same box, you will need to make sure that you assign 2 IP address to the server and use 2 different host name for the same server.
