Warning message
Dial string length
UM 3.15
We are starting to use Nextel cellphones and have found out the maximum characters in the paging device is 32 for outgoing notification. There is a need for 38 in our case, is there a way to increase the number of characters the extra character field takes?
This is the string needed for Nextel: <subscriber's 10 digit cell number>,,,,,,1,1,<call back 10 digit number>,,,,,1,1
Sabas Chois
eschulz Wed, 03/31/2004 - 16:05
  • Cisco Employee,
Can you break up the dialstring between the "Phone Number" field and "Extra digits" field? This can be done through the SA or in Unity Assistant. Unfortunately, I don't believe it can be set through the TUI.
I would try...
Phone Number: <10 digit cell number>
Extra digits: 1,1,<10 digit number>,,,,,1,1
Seconds to wait before dialing extra digits: 6
Eric
