Changing the Data Writing Interval for Real-Time Snapshot
Answered Question
Apr 1st, 2004
Hi, I was wondering if it was possible to set an interval of less than 30 seconds. If that's not possible, does anyone know how to get the same data another way?
Correct Answer by yogeswar about 13 years 4 months ago
One method of retrieving the realtime data is to write an http triggered application that uses the Get Reporting Statistics steps to obtain the desired info and present it back to a browser.
Yogi
As per the CRS-3.1 release notes...
The following data writing intervals have been added: 5, 10, 15, 20, and 25.
You can set the data writing intervals from Cisco CRA Administration by choosing Tools > Real Time Snapshot Config and then choosing the desired
value from the Data Writing drop-down list. These new data writing intervals are useful when wallboard data is required to be updated with a refresh
Yogi
Overall Rating: 5 (3 ratings)
Correct Answer
yogeswar Thu, 04/01/2004 - 03:32
  • Silver, 250 points or more
Yogi
Correct Answer
yogeswar Thu, 04/01/2004 - 03:41
Yogi
petedempsey Thu, 04/01/2004 - 03:51
Thanks for the info yogi. Can you post a link or tell me which document to look for to get more info on the Get Reporting Statistics steps?
Pete
