How to disable spanning-tree on Catalyst 3750 switches ?
Answered Question
I would like to fully-disable spanning-tree on a Catalyst 3750, but a stp process is still running:
swr-A#sh spanning-tree
MST00
Spanning tree enabled protocol mstp
Root ID Priority 32768
Address 0005.01af.870a
Cost 200000
Port 113 (FastEthernet3/0/7)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768 (priority 32768 sys-id-ext 0)
Address 000e.d71b.9c00
Interface Role Sts Cost Prio.Nbr Type
Fa3/0/1 Desg FWD 200000 128.107 P2p
Fa3/0/3 Desg FWD 200000 128.109 P2p
Fa3/0/4 Desg FWD 200000 128.110 P2p
Fa3/0/5 Desg FWD 200000 128.111 Edge P2p
Fa3/0/6 Desg FWD 200000 128.112 Edge P2p
Fa3/0/7 Root FWD 200000 128.113 Shr Bound(STP)
Po1 Desg FWD 100000 128.616 P2p Bound(PVST)
Po2 Desg FWD 100000 128.624 P2p Bound(PVST)
Po3 Desg FWD 100000 128.632 P2p Bound(PVST)
Po4 Desg FWD 100000 128.640 P2p Bound(PVST)
Po5 Desg FWD 100000 128.648 P2p Bound(PVST)
However, I disabled spanning-tree on each VLAN:
swr-A#sh run | inc spanning-tree
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
no spanning-tree vlan 1-2,100-116,900-901
I did the same way to disable spanning-tree on a Catalyst 3550:
swr-B#sh run | inc spanning-tree
spanning-tree mode pvst
no spanning-tree vlan 200
no spanning-tree vlan 201
no spanning-tree vlan 202
no spanning-tree vlan 203
no spanning-tree vlan 204
no spanning-tree vlan 205
no spanning-tree vlan 900
no spanning-tree vlan 901
And it worked:
swr-B#sh spanning-tree
No spanning tree instance exists.
Why can I not disable spanning-tree on a 3750 switch ?
Philippe Muller
Correct Answer by michelpe about 13 years 4 months ago
Philippe,
On this box you are running MST (Multiple Spanning Tree) so disabling spanning tree per vlan doesn't work.
To be able to have the no spanning-tree vlan x
tob e effective you should configure
spantree mode pvst
Overall Rating: 5 (1 ratings)
Correct Answer
michelpe Thu, 04/01/2004 - 19:34
  • Cisco Employee,
Philippe,
spantree mode pvst
  • Cisco Employee,
that should read:
