PIX 515e inside access to dmz
Apr 1st, 2004
I have an issue that i can not seem to see, i am trying to allow inside users access to the dmz, mainly for ftp and www. i know i am overlooking something simple. thanks in advance
Here is the portion of the config that i have
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list dmz permit ip any any
pager lines 24
ip address outside xxx.xxx.xxx.xxx 255.255.255.240
ip address inside yyy.yyy.yyy.yyy 255.255.255.0
ip address dmz zzz.zzz.zzz.zzz 255.255.255.240
ip audit info action alarm
ip audit attack action alarm
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
static (inside,dmz) yyy.yyy.yyy.yyy yyy.yyy.yyy.yyy netmask 255.0.0.0 0 0
static (dmz,outside) zzz.zzz.zzz.zzz zzz.zzz.zzz.zzz netmask 255.255.255.255 0 0
static (inside,dmz) zzz.zzz.zzz.zzz yyy.yyy.yyy.yyy netmask 255.255.255.255 0 0
access-group dmz in interface dmz
pmichaelson Thu, 04/01/2004 - 10:56
The error i seem to have is
Deny TCP (no connection) from zzz.zzz.zzz.zzz/21 to yyy.yyy.yyy.yyy/44038 flags SYN ACK on interface dmz
pmichaelson Fri, 04/02/2004 - 06:30
Here is something odd. i can ping and trace to the dmz with no problem. does anyone have an insight on this?
Phil
pmichaelson Fri, 04/02/2004 - 07:43
i have added this
access-list no_dmz_nat permit ip 207.250.100.144 255.255.255.240 10.0.0.0 255.0.0.0
nat (dmz) 0 access-list no_nat_dmz....
still can not access services on the dmz...but i can ping
pmichaelson Fri, 04/02/2004 - 08:04
i have added this
pmichaelson Fri, 04/02/2004 - 08:05
the log shows this when trying to ftp
Deny TCP (no connection) from 207.250.100.149/21 to 10.8.15.10/54278 flags SYN ACK on interface dmz
looks like some kind of translation is missing, but i cant make heads or tails of it....anyone see the issue?
