Warning message
9216 new Zone not propagated to other swiches in Fabric
Apr 5th, 2004
hello
are they any specials hints to propaged new zone
after creation
customer created new zone ,activate it
but there is not see on other switchs in the fabric
in same Vsan ?
thanks for any advice
JYP
owillins Fri, 04/09/2004 - 07:14
  • Silver, 250 points or more
If you have turned off the `zoneset distribute full' (default : it is turned off), only the active zoneset is sent. Are you using aliases? If so you can enable the distribute full option and see that aliases are propagated. There are also a couple of bugs documented on certain zone sets not getting propagated. Take a look at them also.
Trending Topics: Storage Networking
