Warning message
Cisco 2600 IOS ver 12.0(7)XK1
Apr 5th, 2004
Cisco IOS ver 12.0(7)XK1 was install on a Cisco 2620 router with 16MB Flash and 40MB RAM. It was recently discovered that conducting a ping or traceroute (through the router) caused the router to reload.
I am seeking suggestions on how to rectify this problem. All comments are welcomed
IKRG
Harold Ritter Mon, 04/05/2004 - 16:36
  • Cisco Employee,
12.07)XK1 is actually pretty old. If you only need IP Plus, I would recommend 12.2(23), which is the latest GD release.
Hope this helps,
Harold Ritter Mon, 04/05/2004 - 17:03
  • Cisco Employee,
I just double checked and you will not be able to run 12.2(23) with the amount of memory you have since it requires 16M Flash and 48M DRAM. You can run 12.1(22b) though, which is the latest in the 12.1 train.
Hope this helps,
nladmin2 Wed, 04/07/2004 - 10:41
Thanks for replying to my message. I will try IOS ver 12.1.
