NPE-300 MEMORY ERROR
Answered Question
Apr 5th, 2004
I am receiving the following error on a 7206VXR with a NPE-300 installed:
ROM: DIMM 0 is not the factory fixed/supported 32MB DIMM!
ROM: Please replace DIMM 0 with the original 32MB DIMM.
Can I just order a new MEM-SD-NPE-32MB for this slot, or does it take special memory? Thanks for your help.
Correct Answer by owillins about 13 years 4 months ago
The error you are seeing is because the dimm in slot 0 has been replaced. If the original dimm is not in that slot and if you still have it then place it back in that slot. If you do not have it then the NPE will have to be replaced.
Overall Rating: 5 (1 ratings)
Correct Answer
owillins Fri, 04/09/2004 - 12:20
  • Silver, 250 points or more
