Warning message
Caller-ID on CallManager3.3 with FXO port on Gateway
Apr 5th, 2004
My gateway (2621XM) supports the caller-id command for the FXO port. I run a debug and see the calling parties number coming through, but Callmanager does not seem to push it through to the ip phones. Does Callmanager 3.3(3) support caller-id for FXO ports?
Hin Lee Mon, 04/05/2004 - 16:04
  • Cisco Employee,
Do you have VIC-2FXO-M1?
Are you using H.323?
Can you please show your config?
H. M.
adignan Mon, 04/05/2004 - 17:56
  • Blue, 1500 points or more
hinho is correct in asking if you are using h.323. CallerId on FXO's w/ MGCP is not supported.
sticano Tue, 04/06/2004 - 03:42
I am using MGCP. Forgive my ignorance, but can you use H.323 with Callmanager 3.3(3)?
sticano Tue, 04/06/2004 - 04:09
No I am using VIC-2FXO with MGCP. The later post says that I cannot use MGCP with FXO to use caller-id. I am going to research if I can use H-323 with Callmanager to achieve this goal.
sarmentrout.bok77 Fri, 04/09/2004 - 18:46
You can definitely use the VIC-2FXO with H.323 and CCM3.3.3 and retrieve Caller-ID as we are doing that right now in my network... If you need more specifics, let me know.
We also have MGCP with FXO and I am going to check on the caller-id because I thought it worked as well, but those sites may only use the FXO for SRST dial-out purposes.
adignan Fri, 04/09/2004 - 18:58
Caller-Id with fxo and mgcp definately does not work.
adignan Sat, 04/10/2004 - 07:28
Why don't you post your config, that way I can get a good idea of whats going on.
/andy
sticano Sat, 04/10/2004 - 07:32
dial-peer voice 1 pots
destination-pattern 9T
direct-inward-dial
port 1/0/1
dial-peer voice 100 voip
destination-pattern .......
session target ipv4:10.0.96.200
incoming called-number 1234
dtmf-relay h245-alphanumeric
codec g711ulaw
voice-port 1/0/1
timing hookflash-out 50
caller-id enable
and I have a H.323 gateway defined in Callmanager
adignan Sat, 04/10/2004 - 07:43
Where do you want your inbound calls to the fxo port to go? What number do your inbound extensions begin with? For my example lets say your extension are four digit and start with 34 and you want inbound calls to go to 3400, here is what you would paste in:
voice-port 1/0/1
caller-id enable
connection plar 3400
direct-inward-dial
port 1/0/1
destination-pattern 34..
codec g711ulaw
/andy
sticano Sat, 04/10/2004 - 07:54
I added the plar statement. That makes sense, although I am still getting a busy signal when I dial in. I can debug on the router and see the call come in, it just doesn't seem to go to the callmanager. Any ideas??
Scott
adignan Sat, 04/10/2004 - 07:55
remove the direct inward dial command from your voice pots dial-peer
adignan Sat, 04/10/2004 - 07:46
/andy
adignan Sat, 04/10/2004 - 07:49
/andy
jdiegmueller Sun, 05/02/2004 - 19:02
  • Bronze, 100 points or more
Cisco claims there is no demand for Caller ID on FXO in a CCM/MGCP.
Of course, this is hogwash, but this is how the story goes.
This was the official response I received when researching the same issue...this was over a month ago..
As I mentioned on the phone with you, unfortunately this is a technical limitation at this point that Caller ID is not supported with MGCP and FXO. Here's the link that should address this. Please search the page for 'caller id'.
http://www.cisco.com/warp/public/cc/pd/rt/2600/prodlit/imgcp_ds.htm
There has been an internal feature request open on this, but for now, your options would be to use H.323 on the GW. I hope this helps to explain things a bit. Let me know if there's anything else on this I can clear up for now.
