Warning message
CISCO 1005 Internet Routing
Apr 12th, 2004
Cisco 1005 ----- Hub --- PC
|WAN T1
Cisco 1700 ---- Hub - Cable Modem Router
The Cisco 1005 has the Ethernet setup as 192.168.5.x and the Serial setup as 192.168.4.x. The Cisco 1700 has its Ethernet setup as 192.168.3.x.
From the PC, I can ping my cable modem router which is on 192.168.3.10 (across the T1). However, if I try and do a tracert on an address that is not in the 192.168.x.x range, the trace stops at 192.168.5.1.
I want the PC to be able to browse the web using the cable modem on 192.168.3.10. How do I setup the Cisco 1005 to allow this to happen?
