Warning message
[eap-md5 and eap-tls on csacs at the same time]
Apr 12th, 2004
hi:
i have the following environment:
-wired 802.1x with eap-md5 auth
-wireless with eap-tls auth
-cscas 3.1
if i disallow eap-tls, the wired network authentication works. if i turn it on, only wireless works.
i was under the impression that these 2 had no problem doing this (that is being on at the same time and carrying out auth functions)
anybody seen this?
regards,
c.
jhillend Wed, 04/14/2004 - 13:42
  • Bronze, 100 points or more
Carlos, upgrade to ACS 3.2.3. ACS 3.1 has radio button vs. a check box for this feature (either/or).
