Warning message
PPP Callback Case •CSCea69933
has the following problem been solved
•CSCea69933
Symptoms: Asynchronous calls may fail when the ppp callback accept interface configuration command is configured on a network access server (NAS).
Conditions: This symptom is observed on a Cisco AS5300 when the ppp callback accept interface configuration command is configured on the NAS Group-Async0 interface.
Workaround: There is no workaround.
larry_s
zahmed Wed, 04/14/2004 - 11:28
  • Cisco Employee,
Not yet. Still being worked upon in developement.
~Zulfi
zahmed Thu, 04/15/2004 - 10:08
  • Cisco Employee,
Larry, no I am not aware of any ETA on this bug. But I would strongly suggest you open up a TAC case and get that attached to the bug so that you could get timely updates from TAC on the progress of the bug and/or discussion on a possible workaround (if any).
~Zulfi
