Slipping PRI - Fix in sight?
We have a customer with a slipping T1 circuit that I can't seem to nail down.
It's not only slipping, please see the errors list below.
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is short 133
Description: PSTN Facing PRI
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20031216, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source Line Primary.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (500 seconds elapsed):
20 Line Code Violations, 20 Path Code Violations
1 Slip Secs, 0 Fr Loss Secs, 8 Line Err Secs, 3 Degraded Mins
13 Errored Secs, 3 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 92 15 minute intervals):
1631 Line Code Violations, 4633 Path Code Violations,
107 Slip Secs, 999 Fr Loss Secs, 608 Line Err Secs, 232 Degraded Mins,
917 Errored Secs, 252 Bursty Err Secs, 2 Severely Err Secs, 1002 Unavail Secs
As you can see it's not TOO dirty but it's enough that the users are noticing clicks and noise. Protocols are of course correct, provider has complete an end to end test of the circuit and they see no issues. VG200 gateway running 12.3.6 We have changed the entire gateway, upgraded IOS, changed WIC's.
Thoughts?
ehaseki Wed, 04/14/2004 - 10:38
Maybe you tried but, the main reason for the errors on the PRI interfaces is the clock source. Did you try to change the clock source for that PRI interface?
Regards.
Erdem.
eyabane Wed, 04/14/2004 - 13:43
I would top Erdem by confirming the clock could be one of the sources of the problem.
also, check along the lines of the physical media:
- bad cabing
- any kind of inteference along the cables
Eyabane
rbradfield Wed, 04/14/2004 - 17:24
you don't mention the IOS revision or hardware you are using, I say this because there was aproblem with AIM dsps in 2600s last year which was fixed by an IOS upgrade
Richard.
rbradfield Wed, 04/14/2004 - 17:30
Sorry ignore my last post, did not read the bottom of your original
you might want to look at these commands or something similar
network-clock-participate wic 1
network-clock-select 1 T1 0/1
DRAGI RADOVANOVIC Mon, 04/19/2004 - 07:00
Justin,
have you tried increasing the cable length? This won't probably do much for you but...
Also, what else do you have in that VG200? Send us show diag. This must be one of those "telco's sending a signal that is too strog" cases.
Dragi
If the telco says they have tested the circuit and found no errors, then I would tend to agree. But here is what they tend to do. The extend a circuit from their central office to your location and install a NIU. They then connect a Bert tester to the circuit from the CO end, send an electronic signal to the NIU that loops the NIU. Then the conduct a Bert analysis of the circuit. This confirms the condition of the circuit from the CO to the NIU. What it doesn't do is check the output (or customer side of the NIU). I've found that the NIU can be faulty on the customer side or in some cases the NIU is not provisioned correctly and sends a signal way to strong. In either case you receive erros. What I would do is loop the far end of the circuit. If you have a CSU this can be as easy as looping the CSU, if no CSU then loop the end of the cable. If you terminated onto an RJ45 plug then just loop pins 1,2 to 4,5. Then call the telco back and have them conduct another test to confirm that the circuit is indeed running clean from the CO all the way to your end. Another thought came to mind here. You might also double check with the telco and confirm that the circuit is provisioned like you think it is (ESF and B8ZS)?. If you both aren't provisioned the same you will see what appears to be errors on the circuit.
Good luck.
SHOW DIAG
Slot 0:
VG200 1FE Mainboard Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.0
PCB Serial Number : xxxxxxxxxxx (0)
Part Number : 73-4742-02
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 94 41 06 00 C1 0F 4A 41 44 30 36 31
0x10: 32 30 4D 36 30 20 28 30 29 82 49 12 86 02 04 00
0x20: 81 00 00 00 00 42 41 30 80 00 00 00 00 FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
High Density Voice Port adapter
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Fab Version : 02
RMA Test History : 00
RMA History : 00
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 44 30
0x20: 36 33 35 30 4A 4B 57 03 00 81 00 00 00 00 04 00
VIC Slot 0:
T1 (2 Port) Multi-Flex Trunk (Drop&Insert) WAN Daughter Card
Hardware revision 1.0 Board revision B0
Serial number 27352435 Part number 800-04614-03
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 24 01 00 01 A1 5D 73 50 12 06 03 00 00 00 00
0x30: 58 00 00 00 01 12 17 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Tue 10-Sep-02 19:12 by richc
HDV memory size 524280 heap free 142049
DRAGI RADOVANOVIC Mon, 04/19/2004 - 09:06
You said you'd tried to find network clock commands on your vg200 but there weren't any. vg200 is a strange animal.
Check the clocking again (although it's a pri, and clocking is line, you never know), and also run a debug isdn q921 to see what is going on.
I am not too familar with the output results from the q921.
Here is what i'm seeing.
3w4d: ISDN Se1/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=57 nr=57
3w4d: ISDN Se1/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=58
3w4d: ISDN Se1/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=57 nr=58
3w4d: ISDN Se1/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=58
3w4d: ISDN Se1/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=58 nr=58
3w4d: ISDN Se1/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=59
3w4d: ISDN Se1/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=58 nr=59
3w4d: ISDN Se1/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=59 nr=59
3w4d: ISDN Se1/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=59
3w4d: ISDN Se1/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=60
3w4d: ISDN Se1/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=59 nr=60
3w4d: ISDN Se1/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=60
3w4d: ISDN Se1/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=60 nr=60
3w4d: ISDN Se1/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=61
3w4d: ISDN Se1/0:23 Q921: User TX -> INFO sapi=0 tei=0, ns=60 nr=61
Is there something specific I should be looking for?
Here is a complete config...
Switch type is DMS-100
version 12.3
no parser cache
no service pad
service timestamps debug uptime
service timestamps log uptime
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no logging console
memory-size iomem 15
voice-card 1
codec complexity medium ecan-extended
no aaa new-model
ip subnet-zero
ip tcp synwait-time 13
isdn switch-type primary-dms100
voice call carrier capacity active
voice rtp send-recv
voice service voip
ccm-manager redundant-host 10.17.200.10 10.17.110.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.17.200.10
ccm-manager config
controller T1 1/0
framing esf
clock source line primary
linecode b8zs
cablelength short 133
pri-group timeslots 1-24 service mgcp
description PSTN Facing PRI
controller T1 1/1
shutdown
framing esf
linecode b8zs
interface FastEthernet0/0
description Plug into Voice VLAN 110
ip address 10.17.200.14 255.255.255.0
speed 100
full-duplex
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn channel-id invert extend-bit
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.17.200.1
no ip http server
voice-port 1/0:23
input gain -3
output attenuation 3
echo-cancel coverage 32
voice-port 1/1:23
input gain -3
mgcp
mgcp call-agent 10.17.200.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
application mgcpapp
dial-peer voice 1123 pots
application mgcpapp
end
