Warning message
Removing IPX off of routers and switches
Apr 14th, 2004
I'm in a IP and IPX network environment. We don't have any more need of IPX on our servers. I want to remove IPX off of our routers. How can I do it? We have 3600 series routers and 4006 and 6500 Series switches. Any help will be appreciated. Thanks in advanced!
jgross Thu, 04/15/2004 - 03:28
just configure no ipx routing in flobal configuration mode will remove all the ipx stuff on your router.
Bye
Jo
rmosby Thu, 04/15/2004 - 08:37
So after I run the no ipx routering, I remove the IPX entries from the startup-config file? Also what about the running-config? How do I check if IPX is running even after the change?
Thanks Jo, for you help in this matter.
jgross Thu, 04/15/2004 - 10:55
no, after you configured no ipx routing in global configuration mode, you remove ipx routing from the running config only. All IPX traffic through the router will stop. You not have removed ipx routing from the startup config until now. You can now save the configuration with copy run start. Now you have also removed the ipx routing commands from the startup config.
To check if ipx is removed, you can enter show ipx route at the vommand line, and you will see somthing like IPX Protocol not running.
So it looks like that
Router#conf t
Router(config)#no ipx routing
Router(config)#end
Router#sh run <-- No more IPX in running cfg
Router#sh conf <-- Still IPX commands in startup cfg
Router#copy run start
Router#show conf <-- No more IPX in startup cfg
Router#show ipx route
Router#IPX not running ...
Bye
Jo
rmosby Thu, 04/15/2004 - 13:48
Jo,
THANK YOU THANK YOU...you set me on the right path. I will look into this and let you know how it goes. Thanks so much!!!
willfachi Fri, 04/16/2004 - 14:38
Just a thought - You might want to give your new settings a few hours or a day or so to make sure nothing drastic has happened before you save your running config. Just a small amount of caution might keep you out of a potentially bad situation. Of course it depends on the complexity and size of your organization.
goodluck - willfachi
rmosby Mon, 04/26/2004 - 07:25
Thanks!!!! It work with no problem!!! Thanks so much for everyone for your helped! This save my time is so many ways!!!!
