Odd Menu behavior from 7940
Apr 14th, 2004
I'm developing an XML service to allow users to set wake-up calls, and I'm seeing some weird behavior from my 7940. The phone gets up to the second screen in the application, a PhoneMenu, and then when I try to select one of the two MenuItems, it gets the appropriate URL from the webserver, but still displays the old page, and then if I try to select a MenuItem again, it doesn't go back to the webserver.
I've attached the XML for the two screens; the first one is ampm.xml and the second one is message.xml.
mattsachs Thu, 04/15/2004 - 13:30
There's an undocumented(?) 63-character limit in the length of CiscoIPPhoneMenu/Name items. That was the problem.
aaronw.ca Fri, 04/16/2004 - 05:49
  • Silver, 250 points or more
The length limits are documented in the XML Schema document (CiscoIPPhone.xsd) for the IP Phones. This is available as a download from Cisco Developer Support.
mattsachs Fri, 04/16/2004 - 12:11
Neat, thanks. The only schema I could find is from Call Manager 4.0, we're on 3.3(3), are there any major differences?
aaronw.ca Fri, 04/16/2004 - 12:49
If you obtained it from Cisco Developer Support, isn't it for version 3.3.4? Are you sure you have the 4.0 version?
Nothing significant has changed between versions (that I am aware of). The newer version includes tags to support the model 7970 IP Phone/Communicator, and the old version had minimum values for some tags which have been removed for the most part in the new schema.
rhugo Sun, 09/16/2007 - 17:13
  • Bronze, 100 points or more
Matt -
I am trying to work on a variation of this same wake-up call app service and was wondering if you could repost a copy of your script, if it is not licensed, for comparison to what I have already.
