Problem with VPN Client and network access
Apr 14th, 2004
  • Bronze, 100 points or more
We are running VPN client 4.0.1 on our laptops, and there are a number of users who are getting documents they are using on the internal network (off VPN) corrupted. The initial cause seemed to be the stateful firewall, but I have that turned off, and we are still getting it.
It only seems to be on the machines with VPN client installed, and it is only happening when the user is working on a file direct from the network drive. They are not connecting via the VPN client when the problem occurs.
any suggestions?
William.
chris-davidson Fri, 11/05/2004 - 08:25
Did you get any joy with this ? We seem to be having the same issue.
