PIX 515 crash
Apr 15th, 2004
I'm experiencing a sudden 515 crash apparently without any sign - no crashinfo at all. PIX's are 515 (not E) in failover mode with PIXos 6.3(3).
Any suggestion?
ehirsel Thu, 04/15/2004 - 07:11
  • Silver, 250 points or more
I would contact Cisco TAC about this. One thing they may ask, is if this occurs on a regular basis or not, and if this is the first time.
Herbert Baerten Fri, 03/18/2011 - 02:20
  • Cisco Employee,
Connect a PC to the serial console of the Pix and let it log all console output to a file. When it crashes again, check the console output at the time of the crash; even if no crashinfo is written to flash, it should be written to console (or at least something should be - if not then it could be a power failure).
When did it start? Was there any change in traffic pattern/traffic type (e.g. did you just start using VoIP - just an example)?
Is this firewall handling a different kind of traffic than the other ones that don't crash?
It could also be a hardware failure - one way to check would be to swap a working FW with the crashing one (and swap the configs as well obviously) - if the same physical unit keeps crashing it's likely a hardware issue. If the swapped one starts crashing it's a bug.
hth
Herbert
Herbert Baerten Fri, 03/18/2011 - 02:23
  • Cisco Employee,
One other thing, if you have download access on cisco.com, I would suggest getting the latest 6.3.5.x software version available - if this is a software bug then there's a chance it's fixed in the newer release.
