Script Execution: emailalert.pl VMS2.2
Apr 15th, 2004
Hello together,
maybe you can help me!
Installation VMS 2.2, VMS 2.2 Update 1, MC_IDS 1.2.3,
all IDS_xxxx processes are running.
I want to get an E-Mail if signatures are matching the severity level high, using the Perl script "emailalert.pl"!
The events are coming only from one IDS-Sensor 4235.
I can execute the script manually using the command line. But during normal work it seems that the script won't be activated because no temporary file "idsalert.txt" is created.
Also i tried the actual patches, don't help!
Any Ideas!
Thanks and best regards
Alexander
aossow Mon, 04/26/2004 - 23:24
i have uninstalled the MC IDS 123 and reinstalled, imported the sensor. Then it works!
I know that it is not a good solution, but i had no better idea.
Alexander
