NAT translations and IP secondary Addresses
Answered Question
Apr 16th, 2004
  • Bronze, 100 points or more
I am running out of IP Addresses on the outside interface and want to configure a secondary ip address range. I am using a few ip addresses for NAT translations from the outside interface, but wanted for the NAT pool to use the secondary ip address range from the outside interface instead of the primary ip address range. I have configured the outside interface with the secondary ip address range and changed the ip address range of the NAT pool to the secondary ip address range. I also configured the router to route the secondary ip address range, but did not work for me. Any suggestions would be greatly appreciated
Correct Answer by billtoth about 13 years 4 months ago
rcostilla
It looks like your default gateway may be on the subnet with your primary ip address.
If this is the case then the replies probably have have no route back to your secondary ip address or your nat pool subnet.
another ip address in the same subnet as your secondary block needs to be added to the default gateway interface or the subnet mask needs to changed to range across both of your blocks.
If you already have a route from your isp to the secondary block then you can just remove the secondary ip address and nat through the primary ip address using the secondary pool.
hth
BT
Correct Answer by Georg Pauwen about 13 years 4 months ago
stupid question maybe, but can you check if your PIX allows the translated range (165.95.250.66 165.95.250.126 prefix-length 26) through ? Are the translated addresses arriving at the PIX ?
By the way, NAT and HSRP do not work well together. The standby router does not have the NAT translation table, so when the cutover from the active to the standby router occurs, your connections will time out.
Georg
Overall Rating: 3.7 (4 ratings)
Georg Pauwen Fri, 04/16/2004 - 12:53
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
can you post your configuration ? Here is what I have configured:
interface Ethernet0
ip address 135.13.20.1 255.255.255.252
no ip directed-broadcast
no ip proxy-arp
ip nat inside
interface Serial0
ip address 172.16.1.1 255.255.0.0 secondary
ip address 192.168.1.1 255.255.255.252
no ip proxy-arp
ip nat outside
encapsulation frame-relay
frame-relay map ip 192.168.1.2 102 broadcast
no frame-relay inverse-arp
ip nat pool HOME 172.16.1.1 172.16.1.1 netmask 255.255.0.0
ip nat inside source list 1 pool HOME overload
ip route 0.0.0.0 0.0.0.0 192.168.1.2
Do you at least get your inside addresses translated ?
Georg
Anonymous (not verified) Fri, 04/16/2004 - 13:56
Yes, the inside addresses are being translated. I see the route in the table, but hosts can't access the Internet. Below is the configuration:
interface Vlan416
description Outside Interface
ip address 165.95.250.65 255.255.255.192 secondary
ip address 165.95.241.35 255.255.255.224
ip broadcast-address 165.95.241.63
ip access-group 121 in
ip access-group 120 out
no ip redirects
no ip unreachables
ip nat outside
no ip route-cache
no ip mroute-cache
service-policy output llq
standby 7 ip 165.95.241.33
standby 7 priority 40
standby 7 preempt
interface Vlan50
description Inside Interface
ip address 192.168.2.2 255.255.255.0
ip broadcast-address 192.168.2.255
ip access-group 102 in
ip helper-address 165.95.240.51
no ip redirects
no ip unreachables
ip nat inside
no ip route-cache
no ip mroute-cache
standby 2 ip 192.168.2.1
standby 2 priority 40
standby 2 preempt
router ospf area 10
network 165.95.241.32 0.0.0.31 area 10
network 165.95.250.64 0.0.0.63 area 10
ip nat pool Outsideovrld 165.95.250.66 165.95.250.126 prefix-length 26
ip nat inside source list 21 pool Outsideovrld overload
ip route 0.0.0.0 0.0.0.0 165.95.241.38
access-list 21 deny 192.168.2.2
access-list 21 permit 192.168.2.0 0.0.0.255 log
Note: Vlan 416 is connecting via a fiber link to the pix firewall and then to the Internet. This is the only path out to the Internet. IP Address 165.95.241.38 is the next hop address.
Correct Answer
Georg Pauwen Fri, 04/16/2004 - 22:29
    2017 WAN
Georg
Anonymous (not verified) Mon, 04/19/2004 - 06:03
Hello Pauwen, I really appreciate your help. This is NOT a stupid question. I actually did forget to configure the route in the Pix Firewall. Once I did this, I tested and worked.
Correct Answer
billtoth Sat, 04/17/2004 - 03:30
rcostilla
hth
BT
Anonymous (not verified) Mon, 04/19/2004 - 06:28
Hello Bill,
I tried this prior to adding the secondary ip address to the interface and it did not work for me; but it did not work for me because I did not have the route on the Pix. Once I added the route, I then tried this option as well and worked. I will use this configuration instead of adding the second ip address range to the interface because users noticed a delay when configuring the secondary ip address on the interface. Thank you so much for your input.
