Warning message
1600 Router does not show T1 configuration
Apr 17th, 2004
  • Bronze, 100 points or more
I have a configuration with two 1600 routers connected witha T1 line. I am passing voice and data through this line.
The funny thing is that the system is working(some problems which rarely causes voice distortion) but show running-config command does not show the T1 configuration at all. How can that be? How can the system work and not show the existence of the T1 equipment?
Another similar connection shows the T1 configuration.
"interface Ethernet0
ip address 150.137.133.14 255.255.255.0
interface Serial0
description T1 (HCGS200933001MB) from EDS-2722 to EDS-2741
ip unnumbered Ethernet0
Any explanation? Can this missing configuration cause the problems I am experiencing?
Overall Rating: 5 (1 ratings)
billtoth Sat, 04/17/2004 - 06:40
if your settings are all default then nothing will show up in he configs.
If you make a change (timeslots, encapsulation, etc.) it should appear.
hth
BT
